backup and restore routeur Mickrotik
Hi everybody!
i have my RB2011 mickrotik router i know how to do the backup of the router then restore from the backup.
I am debutant in the config.
Any answer will be welcome
Here you find the manual: http://wiki.mikrotik.com/wiki/Manual:TOC
For backup/restore see this section: https://wiki.mikrotik.com/wiki/Manual:Configuration_Management
Backup and restore is ideal if you are restoring onto the same board/model.
Use export if you want to be able to adapt and move the config around.
