backup and restore
hi,
if not already requested i would like to see a long overdue way to backup and restore config so it can be used not just on the exact same board ! this is the major most annoying ‘bug’ in ROS !! and no, export and import is not what i am looking for, it still requires major modifications in the resulting script and import seems to not work if the script gets a little bigger.
thanks
Jan
