Backup filename looks weird
I upgraded a lot of my RB2011 to 6.08rc and now when i click backup in Winbox it make a file with a weird name instead of the System Id name…
is this normal or a bug?
like this If the name of the Router is Anything Router…back it up and the file looks similar to this…
w_0_w__13042013-0658.backup
Whats up??? is this a bug?
I’m guessing you mean your using 6.0rc8. The most current is 6.0rc13. You need to upgrade and see if you still have the problem.
I do not want to upgrade without knowing if this will fix problem…
All of my RB2011s (10 of them) do this. After I upgraded them in put them in service.
I will downgrade before I upgrade…I believe I made a mistake going to the 6.x beta…all for the pretty icons and colors…when 5.22 suited me just fine.
So, is there anyone who gets properly named backups with 6.08rc or does it change the filename to garbage like mine??
It is working on both of the routers I just tried (CCR, 2011) and I am running rc13.
The new release candidates are much more stable than the past ones.
I have a spare rb2011 I will try it on thanks.
