backup name
in OS v6.05 the Backup name was automatically named.
in OS 6.20 it is frustrating to name manually it every time, especially while working on very many RB.
it is possible to setup somewhere to use the old style in Automatically Backup Name ?
Regards,
Bogdan
In winbox, the file is automatically named if you don’t put any name in the textbox in the backup dialog, the same way it was in older versions. Don’t forget to check “do not encrypt” if you want it the same way as before.
excellent remark. thank you.
