Hello ,
I need to get backup file from RB which has dead ethernets … is there any command that will send the file to my PC?
I can get to RB terminal.
thank you very much.
Hello ,
Type in the PC serial terminal:
/export
Capture the output in a file and give it name ending in .rsc
You can upload this file to your new router and reset configuration from it.
thank you for reply, but it freezes after this command…even if i want to print interfaces…strange
Probably there are more defects than you initially thought.
