How reliable is taking a backup from a RB433 and simply importing it into another RB433?? Will the backup just work?? I’ve been told because of different MAC addresses on each board, some settings from the backup will not port over correctly, hence your new RB433 will not be reliable.
If this is true, is there a way to simply clone a Mikrotik so there is a backup ready for replacing if ever needed?
“/export” - gives complete config with MAC addresses and everything
“/export compact” - gives only config that is different from default. Its much shorter, doesn’t contain MAC addresses, etc.
Use “/export compact” and you can easily “clone” RBs.
That is the point. After a reset-configuration your new router will be completly clean. Then you import all the config from your old one you got with “/export compact”.
That way the new router will be a “clone” of the old one.
please email support, and send us that RSC file that you are using. Also tell us what version you exported it from, and what is the version where you are trying to import it.
