Dear all;
Greetings;
I am asking about the backup restore procedures, I got an old Mikrotik hardware, and I want to replace it by newer, the issue is I didn’t know when you are bringing in new hardware to your network using a restore configuration from the same old hardware inside the network you are actually making a problem for your self! because the new hardware will take the “same” Ethernet MAC addresses of the backup one! I am asking here, is that reasonable? is there any method to avoid this situation?
I don’t know maybe I am not aware of that except presently, but if you don’t use the “reset MAC address” for the all Ethernet of the new hardware, then same Ethernet MAC address will assign to the new Ethernet of the new hardware, I discovered that lately, that means if you not aware of this situation you will end up to have multi Ethernet ports of Mikrotik routers got the same MAC address in the local LAN, I am writing this hopefully someone correct me if I am wrong or I missed something here or maybe this issue had been discussed previously and I am not aware of it.
Many thinks
Khatab
