Hi there,
I would like to ask you how to back up full image of Metarouter running on RB433!? If I carry out classically backup and restore in routerboard, the system is transferred but without image. Is there some another way how to backup routers including Metarouter?In metarouter run OpenWRT
P.
unfortunately you have to backup image files separately. Backup does not restore /file section.
Yes; you have to backup the main routerboard and then each meta router. In some cases backups have been a major problem for me on Meta Router. When memory size was set to 64 backups did not work correctly. Then you have to install the backups in the correct order.
