Hi everyone!
I use several “RBD52G-5HacD2HnD” routers for years now.
Have been using this script for my daily backup of settings on all of them …
2 days ago I updated them to RouterOS to 7.20 ( from 7.19.4 )
Since then this script has stopped working with the following error in log on ALL my installations:
“invalid file name (:export; line 37)”
line 37 of my script looks like : /export show-sensitive file=($sfname.".rsc")
The complete script follows :
:local saveUserDB false
:local saveSysBackup true
:local encryptSysBackup false
:local saveRawExport true
:local FTPServer "192.168.1.1"
:local FTPPort 21
:local FTPUser "user"
:local FTPPass "pass"
:local filename;
:local date [/system clock get date];
:local time [/system clock get time];
:local name [/system identity get name];
:local varHour [:pick $time 0 2];
:local varMin [:pick $time 3 5];
:local varSec [:pick $time 6 8];
:set filename ("Backup"."".$name."".$date."_".$varHour."-".$varMin."-".$varSec);
:local sfname ("/".$filename);
:if ($saveUserDB) do={
/tool user-manager database save name=($sfname.".umb")
:log info message="User Manager DB Backup Finished"
:if ($saveSysBackup) do={
:if ($encryptSysBackup = true) do={ /system backup save name=($sfname.".backup") }
:if ($encryptSysBackup = false) do={ /system backup save dont-encrypt=yes name=($sfname.".backup") }
:log info message="System Backup Finished"
if ($saveRawExport) do={
:log info message="Raw configuration script export Finished"
:delay 5s
:local backupFileName "";
:foreach backupFile in=[/file find] do={
:set backupFileName ("/".[/file get $backupFile name])
:if ([:typeof [:find $backupFileName $sfname]] != "nil") do={
/tool fetch address=$FTPServer port=$FTPPort src-path=$backupFileName user=$FTPUser mode=ftp password=$FTPPass dst-path=$backupFileName upload=yes
:delay 5s
:if ([:typeof [:find [/file get $backupFile name] "Backup_"]]!="nil") do={
/file remove $backupFile
:log info message="Successfully removed Temporary Backup Files"
:log info message="Automatic Backup Completed Successfully"
Any help would be appreciated!
