Backup SXT r2 5nD Lite
Good afternoon everyone!
Usually use the SXT 5HPnD, and when I need to change any equipment, just climb back up the same. I recently bought a new radio radio model, the SXT r2 5ND, but tried to climb back up the model constumo use and I can no longer get on the radio, I have to reset in order to re-access, but if the backup is the same model it works perfectly. Someone answer me know if this radio version have any difference for the backup?
Thank you!
O backup do SXT r2 5nD, só funcionado em no mesmo modelo.
