ashish
October 23, 2007, 6:16am
1
Hi there are some bad blocks on RB 532
[admin@SEMCOM] system resource> pr
uptime: 20d16m14s
version: “2.9.38”
free-memory: 7752kB
total-memory: 30440kB
cpu: “MIPS 4Kc V0.10”
cpu-frequency: 399MHz
cpu-load: 18
free-hdd-space: 93228kB
total-hdd-space: 126976kB
write-sect-since-reboot: 8541
write-sect-total: 12952
bad-blocks: 8
It creates problem sometimes..I means the system hangs or cant boot sometime..What to to to remove the bad blocks.
hai,
18 months ago, i had bad block almost 33 blocks but i don’t have problem. and a few month ago i did do cleaaring it i used format the nand on RB511. sorry i don’t remember for the time.
my action just make clear it.
and tree days ago i started it RB
xxxxxxxx@FT15D0] system resource> pr
uptime: 3d1h52m33s
version: "2.9.46"
free-memory: 20608kB
total-memory: 30432kB
cpu: "MIPS 4Kc V0.10"
cpu-frequency: 264MHz
cpu-load: 5
free-hdd-space: 99944kB
write-sect-since-reboot: 153
write-sect-total: 692383
bad-blocks: 0
normis
October 23, 2007, 6:51am
3
bad blocks is not a problem, RouterOS corrects them and avoids writing on them. If you get more than a hundred (not likely) you can use the mentioned NAND fix command from the BIOS.
tejas
December 6, 2009, 8:48am
4
AP
please use netinstall to reinstall the routerOS.
It fix your problem
please install it from serial null modem cable
check out what is the status
after that you are not getting this kind of problems
hanging problems are due to that bad blocks
aaa
December 6, 2009, 10:47am
5
You can’t install Router OS via serial null modem cable.
tejas
June 8, 2012, 4:35am
6
Sorry boot the device with serial null modem cable and install the ROS by Ethernet and with the help of Netinstall
