bad blocks problem in ros:6.10?!!!!!!!!!!!
Hello everyone
I’ve got a anew rb 433ah with ros ver:6.5 And everything was just fine
but after upgrade to ros ver:6.10 bad blocks counter start raising every reboot by .1% and now its 2.3%
so i downgrade the ros version to 6.4 and the bad blocks counter is now stable at 2.3% and not raise up
  • doing reboot many time with no bad blocks raising
    so is it software bug or what !!!
    note **
    st nand
    zentel ram
                   uptime: 1h12m6s
                  version: 6.4
               build-time: Sep/12/2013 13:52:41
              free-memory: 110.4MiB
             total-memory: 128.0MiB
                      cpu: MIPS 24Kc V7.4
                cpu-count: 1
            cpu-frequency: 680MHz
                 cpu-load: 6%
           free-hdd-space: 47.0MiB
          total-hdd-space: 64.0MiB
  write-sect-since-reboot: 180
         write-sect-total: 6678
               bad-blocks: 2.3%
        architecture-name: mipsbe
               board-name: RB433AH
                 platform: MikroTik
Do you by any chance have a microSD card inserted in your board? I had same issues you described with my rb493g when I had microSD inserted, nevertheless it was not being used for anything. I’ve put my microSD card in my rb493g in the first place just in case I need it someday because it is a bit annoying having to open the case and take the board out to insert the microSD card. I removed microSD card, re-netinstalled my routerboard and it is running without any issues since.
JF.
i have no microSD card inserted
downgrade to 6.5 and its not raising any more and working good
i thhink this problem hapen with 433ah with (st) nand only
