Why/how does the rb get bad blocks, and is it bad?
a few of them are ok, if you get more than 100 - you can use the “format NAND” in the BIOS to correct them. They will not cause problems anyway, as RouterOS doesn’t use blocks marked as bad.
Thanks for the info!
