bad ping and high latency
Need help, I and several persons in the forum that has the same problem
High latency in the links and loss of packetes in the clients (cpe). > > Prove> with different types of plates. My cpes connectan pppoe , i have high latency y most packet lost> the noise floor -96
2 R name=“NODO con ampli” mtu=1500 mac-address=00:02:6F:24:6A:62 arp=enabled
disable-running-check=no interface-type=Atheros AR5213
radio-name=“Nodo28 WIFI” mode=ap-bridge ssid=“Nodo28 WDS” area=“”
frequency-mode=manual-txpower country=argentina antenna-gain=0
frequency=2432 band=2.4ghz-b scan-list=default rate-set=default
supported-rates-b=1Mbps,2Mbps,5.5Mbps,11Mbps
supported-rates-a/g=6Mbps,9Mbps,12Mbps,18Mbps,24Mbps,36Mbps,48Mbps,
54Mbps
basic-rates-b=1Mbps basic-rates-a/g=6Mbps max-station-count=2007
ack-timeout=dynamic tx-power-mode=default noise-floor-threshold=default
periodic-calibration=enabled periodic-calibration-interval=60
burst-time=disabled dfs-mode=none antenna-mode=ant-a wds-mode=disabled
wds-default-bridge=none wds-default-cost=100 wds-cost-range=50-150
wds-ignore-ssid=no update-stats-interval=disabled
default-authentication=yes default-forwarding=no default-ap-tx-limit=0
default-client-tx-limit=0 proprietary-extensions=post-2.9.25
hide-ssid=no security-profile=default disconnect-timeout=3s
on-fail-retry-time=100ms preamble-mode=both compression=no
allow-sharedkey=no
ping …
[admin@Main gateway server] > ping 192.168.32.179
192.168.32.179 64 byte ping: ttl=64 time=314 ms
192.168.32.179 64 byte ping: ttl=64 time=479 ms
192.168.32.179 64 byte ping: ttl=64 time=609 ms
192.168.32.179 64 byte ping: ttl=64 time=649 ms
192.168.32.179 64 byte ping: ttl=64 time=429 ms
192.168.32.179 ping timeout
192.168.32.179 64 byte ping: ttl=64 time=489 ms
192.168.32.179 64 byte ping: ttl=64 time=3 ms
192.168.32.179 64 byte ping: ttl=64 time=379 ms
192.168.32.179 64 byte ping: ttl=64 time=129 ms
192.168.32.179 64 byte ping: ttl=64 time=62 ms
192.168.32.179 64 byte ping: ttl=64 time=199 ms
192.168.32.179 64 byte ping: ttl=64 time=149 ms
16 packets transmitted, 14 packets received, 12% packet loss
round-trip min/avg/max = 3/305.1/649 ms
thanks walter rosso fron argentina
Make sure AP is not operating under heavy traffic load. We need more information about your configuration (clients connected, connection quality, traffic generated on the wireless interface, etc.)
You can prioritize ICMP packets over wireless network to get stable pings.
  • how about channel at your place [on your wireless channel], maybe overloaded channel.
  • how about distance between AP to CPE
  • how about pointing the antenna
  • how about security your wirelessly
regards
Hasbullah.com
