Bad remote-as
I’m stumped. Either I’m missing something or the remote peer is configured wrong.
Initially I was getting:
00:05:11 route,bgp,error Received notification
00:05:11 route,bgp,error     OPEN error: bad remote-as
so after a little playing I intentionally broke the remote as and got:
00:00:21 route,bgp,error Invalid remote AS, expected 29950
00:00:21 route,bgp,error     RemoteAddress=1.1.1.64
00:00:21 route,bgp,error     RemoteAs=29951
AS 29951 is indeed that correct AS so I changed the peer config back, but the original error is still present. Here is the full debug, does anyone else see something I’m missing or any suggestions on what I might try?
00:05:10 system,info bgp peer blah changed by admin
00:05:11 route,bgp,debug Update source
00:05:11 route,bgp,debug     Address=1.1.1.181
00:05:11 route,bgp,debug Connecting
00:05:11 route,bgp,debug     RemoteAddress=1.1.1.64
00:05:11 route,bgp,debug,state Entering Connect state
00:05:11 route,bgp,debug,state     RemoteAddress=1.1.1.64
00:05:11 route,bgp,info TCP connection established
00:05:11 route,bgp,info     RemoteAddress=1.1.1.64
00:05:11 route,bgp,debug,state Entering OpenSent state
00:05:11 route,bgp,debug,packet,raw Sent OPEN message
00:05:11 route,bgp,debug,packet,raw     RemoteAddress=1.1.1.64
00:05:11 route,bgp,debug,packet,raw     Length=45
00:05:11 route,bgp,debug,packet,raw     FF FF FF FF FF FF FF FF FF FF FF FF FF FF
FF FF
00:05:11 route,bgp,debug,packet,raw     00 2D 01 04 D7 04 00 B4 43 8A 6F 8C 10 02
0E 02
00:05:11 route,bgp,debug,packet,raw     00 41 04 00 00 D7 04 01 04 00 01 00 01
00:05:11 route,bgp,debug,packet Sent OPEN message
00:05:11 route,bgp,debug,packet     RemoteAddress=1.1.1.64
00:05:11 route,bgp,debug,packet     Length=45
00:05:11 route,bgp,debug,packet OPEN Message
00:05:11 route,bgp,debug,packet     MessageLength=45
00:05:11 route,bgp,debug,packet,raw Received OPEN packet
FF FF
00:05:11 route,bgp,debug,packet,raw     00 2D 01 04 74 FF 00 5A 45 1B AD 22 10 02
0E 01
00:05:11 route,bgp,debug,packet,raw     04 00 01 00 01 02 00 41 04 00 00 74 FF
00:05:11 route,bgp,debug,packet OPEN Message capabilities option
00:05:11 route,bgp,debug,packet     Lenght=14
00:05:11 route,bgp,debug,packet OPEN Message capability
00:05:11 route,bgp,debug,packet     Code=multiprotocol capability
00:05:11 route,bgp,debug,packet     Lenght=4
00:05:11 route,bgp,debug,packet     Code=route refresh capability
00:05:11 route,bgp,debug,packet     Lenght=0
00:05:11 route,bgp,debug,packet     Code=AS 4-octet capability
00:05:11 route,bgp,debug,state Entering OpenConfirm state
00:05:11 route,bgp,debug,packet,raw Sent KEEPALIVE message
00:05:11 route,bgp,debug,packet,raw     Length=19
FF FF
00:05:11 route,bgp,debug,packet,raw     00 13 04
00:05:11 route,bgp,debug,packet Sent KEEPALIVE message
00:05:11 route,bgp,debug,packet     Length=19
00:05:11 route,bgp,debug,packet NOTIFICATION Message
00:05:11 route,bgp,debug,packet     MessageLength=21
00:05:11 route,bgp,debug,packet,raw Received NOTIFICATION packet
00:05:11 route,bgp,debug,packet,raw     Length=21
FF FF
00:05:11 route,bgp,debug,packet,raw     00 15 03 02 02
00:05:11 route,bgp,debug,state Entering Idle state
00:05:11 route,bgp,debug,packet,raw Sent NOTIFICATION message
00:05:11 route,bgp,debug,packet,raw     cease, subcode=0
FF FF
00:05:11 route,bgp,debug,packet,raw     00 15 03 06 00
00:05:11 route,bgp,debug,packet Sent NOTIFICATION message
00:05:11 route,bgp,debug,packet     Length=21
You have configured wrong AS numbers
You are trying to connect to 29950 but remote peer has 29951
Yes, I intentionally broke it to see if the error changed. When I intentionally misconfigured it for remote as 29950 the error is very clear that 29950 is wrong. But when I change it to the correct ASN (29951) I continue to get a remote ASN error but without anything specific mentioned as the problem.
I’m really leaning toward a provider config issue, but even that isn’t clear from any of the errors.
And did you set correct AS number on your router in BGP instance config?
Yup. I’m leaning toward the provider doesn’t have the remote ASN set correctly (my correct ASN), would this be your conclusion as well?
 0 *  name="default" as=55044 router-id=1.1.1.181 redistribute-connected=no
      redistribute-static=no redistribute-rip=no redistribute-ospf=no
      redistribute-other-bgp=no out-filter="" client-to-client-reflection=yes
      ignore-as-path-len=no routing-table=""
[admin@MikroTik] /routing bgp> peer print
Flags: X - disabled, E - established
 #   INSTANCE         REMOTE-ADDRESS                                  REMOTE-AS
 0   default          1.1.1.64                                   29951
It does appear the remote side has misconfigured your AS,
(assuming your AS is 55044)
The remote side had configured our peer ASN to be the same as theirs.
Thanks for the help, I thought it was on their side, but I like to have another opinion before confronting a provider.
