Equis
August 26, 2007, 10:51am
1
Hello
I have made a simple 5ghz link over 15kms, very clean LOS
One end is on a tower, the other is on a steel shed on a hill on a 3 meter pole.
I got bad signal -88 at 3 meters on the pole, after messing aroung for ever we found at 1 meter on the pole got -75
How can lowering a grid 2 meters on a pole make it so much better?
bushy
August 26, 2007, 2:36pm
2
Reflections from the steel shed probably , when you lowered it you found a ādead zoneā
Equis
August 26, 2007, 11:23pm
3
I posted on another forum and they said the same, they also said it could be bouncing of the ground.
This is something I never knew existed!
GWISA
August 27, 2007, 7:33am
4
You should also familiarise yourself with something called the Fresnel Zone⦠combine tis with reflections, and you are destined for interesting times!
http://en.wikipedia.org/wiki/Fresnel_zone
Equis
August 27, 2007, 9:05am
5
My head started to hurt before I even clicked the link
Iām not as bright as some
Iāll do some reading
