bad wireless connection after change of hardware
hallo,
i had stable wireless link with pings about 1ms and 20mbit bandwidth but i had to change the cpe-antenna on client site. so there is a new cpe-antenna with a new 411 routerboard and new wireless card (CM9). the hardware before was also a 411 routerboard with a cm9 wireless card.
then i manually cloned the settings and now the wireless link is terrible.
here some pings over the wireless link (before 99% 1ms)
10.0.0.2 64 byte ping: ttl=64 time=377 ms
10.0.0.2 64 byte ping: ttl=64 time=115 ms
10.0.0.2 64 byte ping: ttl=64 time=229 ms
10.0.0.2 64 byte ping: ttl=64 time=191 ms
10.0.0.2 64 byte ping: ttl=64 time=143 ms
10.0.0.2 64 byte ping: ttl=64 time=54 ms
10.0.0.2 64 byte ping: ttl=64 time=208 ms
10.0.0.2 64 byte ping: ttl=64 time=3 ms
10.0.0.2 64 byte ping: ttl=64 time=26 ms
10.0.0.2 64 byte ping: ttl=64 time=240 ms
at the moment fluctuating bandwidth from 100kbit till 2 mbit (tested with bandwidth test) :frowning:
here some info from monitor from client site
 status: connected-to-ess
                   band: 5ghz
              frequency: 5500MHz
                tx-rate: "48Mbps"
                rx-rate: "6Mbps" fluctuating by second, either 6 or 48Mbps
                  bssid: 00:0B:6B:D9:8C:BE
             radio-name: "000B6BD98CBE"
        signal-strength: -76dBm
     tx-signal-strength: -75dBm
            noise-floor: -98dBm
        signal-to-noise: 22dB
                 tx-ccq: 45%
                 rx-ccq: 32%
           p-throughput: 24144
         overall-tx-ccq: 45%
  authenticated-clients: 1
               wds-link: no
                nstreme: yes
                polling: yes
          csma-disabled: no
           framing-mode: none
       routeros-version: "3.10"
    802.1x-port-enabled: yes
anybody an idea where the problem is? can it be that the new wireless card is broken?
thanks in advance!
now I changed the hardware again. new board an new wireless card and I have the same terrible connection. :frowning:
so the wireless card is not broken. i have no idea what it can be.
since i changed the hardware the link is terrible. before it runs for 2 weeks with no problems. that doesnt make sense.
Over night the wireless link ist ok. Pings and Bandwidth are good.
Now the tx-ccq rx-ccq is about 80% before it was 30-40% ? I changed nothing!
Anybody an idea? Really strange ..
