Hi, I have not worked bonding interface in mode balance-alb and balance-tlb through a tunnels eoip. Bonding interface is connected, and the pings go with intervals for about 10 seconds to 1 - 30 packets. In this balance-rr mode works fine and sends the packets to the queue for all interfaces.
Settings:
/interface bonding
add arp=enabled arp-interval=100ms arp-ip-targets=10.0.10.1,10.0.10.2,10.0.10.3,10.0.10.4 disabled=no down-delay=0ms lacp-rate=30secs \
link-monitoring=arp mii-interval=100ms mode=balance-alb mtu=1500 name=bond primary=eoip1 slaves=eoip1,eoip2,eoip3,eoip4 \
transmit-hash-policy=layer-2 up-delay=0ms
/interface eoip
add arp=enabled disabled=no l2mtu=65535 local-address=10.0.1.1 mac-address=FE:C3:8B:77:C1:40 mtu=1500 name=eoip1 remote-address=10.0.10.1 \
tunnel-id=0
add arp=enabled disabled=no l2mtu=65535 local-address=10.0.1.2 mac-address=FE:E3:F6:9F:09:A7 mtu=1500 name=eoip2 remote-address=10.0.10.2 \
tunnel-id=1
add arp=enabled disabled=no l2mtu=65535 local-address=10.0.1.3 mac-address=FE:1C:2C:43:3E:F5 mtu=1500 name=eoip3 remote-address=10.0.10.3 \
tunnel-id=2
add arp=enabled disabled=no l2mtu=65535 local-address=10.0.1.4 mac-address=FE:26:A8:40:18:38 mtu=1500 name=eoip4 remote-address=10.0.10.4 \
tunnel-id=3
versions:
model RB750
firmware: 2.36
routerboard: 5.6
On the other side the same settings.
Do you have any solutions?
ping.txt (17.2 KB)
