Hi Can any one help I am using RB4011iGS+ and I am using Balance RR my internet connection for Virgin Media I am using 4 Ethernet ports from Modem and then Balance RR and Bridge to SFP port to my UDM Pro and it work but after some time it drops Balancing on RX and drops to one slave but TX still uses all 4 Slaves It is driving me crazy and if any one can point me in right direction. the TX balances perfect but RX not so much.
dec/23/2021 16:04:38 by RouterOS 7.1.1
software id = EADM-A60K
model = RB4011iGS+
serial number = F0280F868726
add admin-mac=C4:AD:34:BD:B1:39 auto-mac=no comment=defconf name=bridge
add arp=disabled name=vmbridge protocol-mode=none
set [ find default-name=sfp-sfpplus1 ] advertise=10000M-full
/interface bonding
add arp=disabled link-monitoring=none name=vmbond slaves=
ether4,ether5,ether6,ether7
add comment=defconf name=WAN
add comment=defconf name=LAN
/interface lte apn
set [ find default=yes ] ip-type=ipv4
/port
set 0 name=serial0
set 1 name=serial1
/routing bgp template
set default as=65530 disabled=no name=default output.network=bgp-networks
/routing ospf instance
add name=default-v2
/routing ospf area
add disabled=yes instance=default-v2 name=backbone-v2
add bridge=bridge comment=defconf ingress-filtering=no interface=ether2
add bridge=bridge comment=defconf ingress-filtering=no interface=ether3
add bridge=bridge comment=defconf ingress-filtering=no interface=ether8
add bridge=bridge ingress-filtering=no interface=ether1
add bridge=vmbridge ingress-filtering=no interface=vmbond
add bridge=vmbridge ingress-filtering=no interface=sfp-sfpplus1
/ip settings
set max-neighbor-entries=8192
/ipv6 settings
/ip dhcp-client
add interface=bridge
add address=192.168.88.0/24 comment=defconf dns-server=192.168.88.1 gateway=
192.168.88.1
set allow-remote-requests=yes
/ip dns static
add action=accept chain=input comment=
"defconf: accept established,related,untracked" connection-state=
add action=drop chain=input comment="defconf: drop invalid" connection-state=
invalid
add action=drop chain=input comment="defconf: drop all not coming from LAN"
in-interface-list=!LAN
add action=accept chain=forward comment="defconf: accept in ipsec policy"
ipsec-policy=in,ipsec
add action=accept chain=forward comment="defconf: accept out ipsec policy"
ipsec-policy=out,ipsec
add action=fasttrack-connection chain=forward comment="defconf: fasttrack"
"defconf: accept established,related, untracked" connection-state=
add action=drop chain=forward comment="defconf: drop invalid" connection-state=
invalid
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed"
connection-nat-state=!dstnat connection-state=new in-interface-list=WAN
add action=masquerade chain=srcnat comment="defconf: masquerade" ipsec-policy=
out,none out-interface-list=WAN
/system clock
set time-zone-name=Europe/London
/system resource irq rps
set sfp-sfpplus1 disabled=no
/tool mac-server
/tool mac-server mac-winbox
