Balanced ECMP on IPv6
Please help me, all my routers are Mikrotik ver 6.39.1, my scenario:
ROUTER – ROUTER
The routers are interconnected by two vlans and raised the OPSFv3 in all of them, the neighbos are in full:
[saulo.corbellari@RTD.VVH.JBT.BLOCO27] /routing ospf-v3 neighbor> print
0 instance=default router-id=10.1.255.65 address=fe80::d6ca:6dff:fe71:219 interface=vlan12
priority=1 dr=10.0.255.57 backup-dr=10.1.255.67 state=“Full” state-changes=4
ls-retransmits=0 ls-requests=0 db-summaries=0 adjacency=7h34m2s
1 instance=default router-id=10.1.255.65 address=fe80::d6ca:6dff:fe71:21a interface=vlan13
priority=1 dr=10.0.255.57 backup-dr=10.1.255.65 state=“Full” state-changes=11
ls-retransmits=0 ls-requests=0 db-summaries=0 adjacency=5h25m41s
The routes are installed with the same cost of OSPF and with two gateways by FE80 ::
But traffic is not balanced
Or you use only a link as in the figure or the downaload goes on one side and the upload on the other. On my ipv4 it is the same scenario but I use a cisco router and it works normal.
Nobody? It´s something simple in ipv4, but i want know if its a bug in Ipv6!
I’m getting the same scenario over here. I think its a bug
v6.45.9 long-term
RouterOS v6 does not support IPv6 ECMP.
This feature is implemented in ROS v7 beta.
