Balancing ether1 (l2tp1,lptp2)+ether2(l2tp3,l2tp4)
Can anybody help with settings on my routerboard? :
  • RB450G RouterOS v4.11
  • in interfaces ether1,ether2 (dhcp clients of the same gateway 10.73.64.1)
  • in vpn l2tp1-l2tp4 (vpn auth server adresses passes through 10.73.64.1)
  • out interfaces ether3-5 (swithed on master ether3) - lan NATted
I’ve used PCC balancing by manual, but I can’t understand how to do this: two l2tp on ether1 and another two l2tp on ether2
vpn connections has the equal bandwidths. What I can achieve it’s all l2tp balancing on only ether interface :frowning:
for now, you cannot set src-address for L2TP tunnel, so it’s impossible to select routing table for L2TP tunnels with the same server address…
