Balancing on one interface
I have big problem! I have 2 internet connections from different ISP! I want use balancing on mikrotik on 1 interface. I think, I want set up more gateways. Can someone help me? My ICQ munber is 249-286-839!
Please help me!
David from Slovakia!
I think it should help to your:
http://www.mikrotik.com/docs/ros/2.8/appex/scripting1.content#11.2.4.3
specify what do you mean balancing on 1 inerface ?
Yes! I have one interface to LAN and one interface to WAN port! I have two or more DSL connections and i want make load balancing from 2x WAN to Lan. This two internet connections I want to connect to one ethernet card!
If you know, what I can realize it, please write it step by step!
IP of DSL router 1 is 192.168.3.2 Mask: 255.255.255.0
IP of DSL router 2 is 192.168.3.1 Mask: 255.255.255.0
IP of LAN interface is 192.168.1.1 Mask: 255.255.255.0
ghm, I think this example is similar to your situation, check it:
http://www.mikrotik.com/docs/ros/2.9/ip/route.content#8.48.3.1
How would this be done if the gateway addresses are not static but all ISP connections are using dynamically assigned gateways (i.e. PPPoE)?
–Tom
I have static IP and gateway
