Hi
Can anybody perhaps let me know if you have come across this problem before and if you perhaps have a solution.
We have a Mikrotik RB433 routerboard running ROS 3.2 but the same problem with version 4.0.
When I select the band 2.4GHz-B/G, Clients that only support the B standard can’t connect but G client work fine.
When I select the B only option then B clients can connect fine.
I would like to have the 2.4GHz-B/G band enabled so that B clients can connect with no problem and G clients can also connect.
But when there are no B clients in range then the G clients get full speed.
In other words. What I expect from the B/G option doesn’t work.
Thanks a lot
