Band Width Measurement
The more I learn about Mikrotik ROS the more things I find out I do not know…
I am using user manager with hotspots on RB750. It took a loooong time for me to figure out some things about User Manager, but I am getting there…
I am wondering what I am doing wrong. I give the users a set time to use a set amount of total transfer. It works for the biggest part. And I am surprised at the volumes this little computer can handle.
User Manager and the hotspot does not stop transfer when the transfer limit is reached, it cuts of after up to 47 Mega Byte more than wat was allowed to the user has been used. It is not always the same amount over but it is allways over.
Is it something I am doing wrong, or is that just the way User Manager works? Is the bandwidth measurement intime and/or correct?
Hi
I am a real novice at this, but might have an idea.
I am not too sure if this will work, but change the time between updates to the Radius server.
This can be done through winbox>ip>hotspot>hotspot server
Let me know if this helps…
