Bandwidth Cap question
I am not trying to do any QOS,traffic shaping or rate limiting all I want to do is stop an IP when a bandwidth limit is reached.
I found this is in the wiki.
http://wiki.mikrotik.com/wiki/Limiting_a_user_to_a_given_amount_of_traffic_II
My question is…
This is from 2010, is there a newer or better way to go about setting data limits on users/IP.
That way is fine except that a reboot/power failure will reset all stats. The example is on a daily basis, so this is probably fine, but if you wanted to keep track over a longer period, you might look into using the hotspot feature or the user manager. There might be another way to script it… ?
