Bandwidth control between local IP address
Hi all,
Say if I need to limit the bandwidth between 192.168.88.20 and 192.168.88.30, how do I do it?
Tried to do it from Queues, but after I put the IP in the Dst IP field and apply, nothing seems happened. No traffic was monitored or limited.
Thanks for any idea.
Hello, maby can this help you
http://www.wirelessinfo.be/index.php/mikrotik/pages/queues
In dutch but see the printscreens a made.
Does the Queue function work if the router is in Bridge mode? I am not able to get any limiting at the moment.
My setup is as follows:
INTERNET – > DSL-Router – > eth1.Mikrotik(Bridge Mode) — > eth2-eth5.Computers
My DSL connection is 12Mbit down and 650Kbit upload. I would like to limit each computer on eth2-eth5 to 3Mbit each. I do not want to limit total bandwith of eth2-eth5 combined to 3Mbit (if that makes sense). So in the end, if each PC is downloading at full allowed speed, each PC would download at 3Mbit.
Any help on this would be appreciated. Thanks,
FDM
You can use the Queue to limit the bandwidth of the ports. Just select the port you want to limit at the TARGET field when you make the Queue.
