Hello Pukkita, thank you for the assistance…it is much appreciated!!!
Here is the configuration export:
MikroTik RouterOS 5.22 (c) 1999-2012 http://www.mikrotik.com/
[XXX@MikroTik] > /export hide-sensitive
# feb/02/2016 09:40:24 by RouterOS 5.22
add admin-mac=00:00:00:00:00:00 ageing-time=5m arp=enabled auto-mac=yes \
disabled=no forward-delay=15s l2mtu=1598 max-message-age=20s mtu=1500 \
name="Traffic Control Bridge" priority=0x8000 protocol-mode=none \
transmit-hold-count=6
set 0 arp=enabled auto-negotiation=yes disabled=no full-duplex=yes l2mtu=1600 \
mac-address=00:0C:42:EB:6A:20 mtu=1500 name=ether12 speed=100Mbps
set 1 arp=enabled auto-negotiation=yes disabled=no full-duplex=yes l2mtu=1600 \
mac-address=00:0C:42:EB:6A:21 mtu=1500 name=ether13 speed=100Mbps
set 2 arp=enabled auto-negotiation=yes bandwidth=unlimited/unlimited \
disabled=no full-duplex=yes l2mtu=1598 mac-address=00:0C:42:EB:6A:15 \
master-port=none mtu=1500 name=ether1 speed=1Gbps
set 3 arp=enabled auto-negotiation=yes bandwidth=unlimited/unlimited \
disabled=no full-duplex=yes l2mtu=1598 mac-address=00:0C:42:EB:6A:16 \
master-port=none mtu=1500 name=ether2 speed=100Mbps
set 4 arp=enabled auto-negotiation=yes bandwidth=unlimited/unlimited \
disabled=no full-duplex=yes l2mtu=1598 mac-address=00:0C:42:EB:6A:17 \
master-port=none mtu=1500 name=03-Office speed=100Mbps
set 5 arp=enabled auto-negotiation=yes bandwidth=unlimited/unlimited \
disabled=no full-duplex=yes l2mtu=1598 mac-address=00:0C:42:EB:6A:18 \
master-port=none mtu=1500 name=04-LargeDorm speed=100Mbps
set 6 arp=enabled auto-negotiation=yes bandwidth=unlimited/unlimited \
disabled=no full-duplex=yes l2mtu=1598 mac-address=00:0C:42:EB:6A:19 \
master-port=none mtu=1500 name="05-Guest house" speed=100Mbps
set 7 arp=enabled auto-negotiation=yes bandwidth=unlimited/unlimited \
disabled=no full-duplex=yes l2mtu=1598 mac-address=00:0C:42:EB:6A:1A \
master-port=none mtu=1500 name="06-Red Barn" speed=100Mbps
set 8 arp=enabled auto-negotiation=yes bandwidth=unlimited/unlimited \
disabled=no full-duplex=yes l2mtu=1598 mac-address=00:0C:42:EB:6A:1B \
master-port=none mtu=1500 name=07-GenTech speed=1Gbps
set 9 arp=enabled auto-negotiation=yes bandwidth=unlimited/unlimited \
disabled=no full-duplex=yes l2mtu=1598 mac-address=00:0C:42:EB:6A:1C \
master-port=none mtu=1500 name=08-Solplex speed=1Gbps
set 10 arp=enabled auto-negotiation=yes bandwidth=unlimited/unlimited \
disabled=no full-duplex=yes l2mtu=1598 mac-address=00:0C:42:EB:6A:1D \
master-port=none mtu=1500 name=09-Omega speed=1Gbps
set 11 arp=enabled auto-negotiation=yes bandwidth=unlimited/unlimited \
disabled=no full-duplex=yes l2mtu=1598 mac-address=00:0C:42:EB:6A:1E \
master-port=none mtu=1500 name=ether10 speed=100Mbps
set 12 arp=enabled auto-negotiation=yes disabled=no full-duplex=yes l2mtu=\
1600 mac-address=00:0C:42:EB:6A:1F mtu=1500 name=ether11 speed=100Mbps
/interface ethernet switch
set 0 mirror-source=none mirror-target=none name=switch2
set 1 mirror-source=none mirror-target=none name=switch1
/ip hotspot profile
set [ find default=yes ] dns-name="" hotspot-address=0.0.0.0 html-directory=\
hotspot http-cookie-lifetime=3d http-proxy=0.0.0.0:0 login-by=\
cookie,http-chap name=default rate-limit="" smtp-server=0.0.0.0 \
split-user-domain=no use-radius=no
/ip hotspot user profile
set [ find default=yes ] name=default shared-users=1 status-autorefresh=1m \
transparent-proxy=no
/ip ipsec proposal
set [ find default=yes ] auth-algorithms=sha1 disabled=no enc-algorithms=3des \
lifetime=30m name=default pfs-group=modp1024
add name="Lower Speed" ranges=10.0.0.50-10.0.0.254
add name="Higher Speed" ranges=10.0.0.20-10.0.0.49
add name="Network Devices" ranges=10.0.0.15-10.0.0.19
add address-pool="Lower Speed" authoritative=after-2sec-delay bootp-support=\
static disabled=no interface="Traffic Control Bridge" lease-time=3d name=\
server2
/port
set 0 baud-rate=115200 data-bits=8 flow-control=none name=serial0 parity=none \
stop-bits=1
set 1 baud-rate=115200 data-bits=8 flow-control=none name=serial1 parity=none \
stop-bits=1
/ppp profile
set 0 change-tcp-mss=yes name=default only-one=default use-compression=\
default use-encryption=default use-mpls=default use-vj-compression=\
default
set 1 change-tcp-mss=yes name=default-encryption only-one=default \
use-compression=default use-encryption=yes use-mpls=default \
use-vj-compression=default
/queue tree
add burst-limit=0 burst-threshold=0 burst-time=0s disabled=no limit-at=0 \
max-limit=0 name="Master Queue" packet-mark="" parent=global-out \
priority=8
/queue type
set 0 kind=pfifo name=default pfifo-limit=50
set 1 kind=pfifo name=ethernet-default pfifo-limit=50
set 2 kind=sfq name=wireless-default sfq-allot=1514 sfq-perturb=5
set 3 kind=red name=synchronous-default red-avg-packet=1000 red-burst=20 \
red-limit=60 red-max-threshold=50 red-min-threshold=10
set 4 kind=sfq name=hotspot-default sfq-allot=1514 sfq-perturb=5
add kind=pcq name="Lower Speed Download" pcq-burst-rate=0 \
pcq-burst-threshold=0 pcq-burst-time=10s pcq-classifier=src-address \
pcq-dst-address-mask=24 pcq-dst-address6-mask=64 pcq-limit=20 pcq-rate=1M \
pcq-src-address-mask=24 pcq-src-address6-mask=64 pcq-total-limit=7500
add kind=pcq name="Lower Speed Upload" pcq-burst-rate=0 pcq-burst-threshold=0 \
pcq-burst-time=10s pcq-classifier=dst-address pcq-dst-address-mask=24 \
pcq-dst-address6-mask=64 pcq-limit=20 pcq-rate=1M pcq-src-address-mask=24 \
pcq-src-address6-mask=64 pcq-total-limit=6000
add kind=pcq name="Higher Speed Upload" pcq-burst-rate=0 pcq-burst-threshold=\
0 pcq-burst-time=10s pcq-classifier=dst-address pcq-dst-address-mask=24 \
pcq-dst-address6-mask=64 pcq-limit=20 pcq-rate=2M pcq-src-address-mask=24 \
add kind=pcq name="Higher Speed Download" pcq-burst-rate=0 \
pcq-dst-address-mask=24 pcq-dst-address6-mask=64 pcq-limit=20 pcq-rate=2M \
add kind=sfq name="Master Queue" sfq-allot=2000000 sfq-perturb=5
set 10 kind=none name=only-hardware-queue
set 11 kind=mq-pfifo mq-pfifo-limit=50 name=multi-queue-ethernet-default
set 12 kind=pfifo name=default-small pfifo-limit=10
/queue tree
max-limit=0 name="Lower Speed Download" packet-mark=\
"Lower Speed Download" parent="Master Queue" priority=8 queue=\
max-limit=0 name="Lower Speed Upload" packet-mark="Lower Speed Upload" \
parent="Master Queue" priority=8 queue="Lower Speed Upload"
max-limit=0 name="Higher Speed Upload" packet-mark="Higher Speed Upload" \
parent="Master Queue" priority=8 queue="Higher Speed Upload"
max-limit=0 name="Higher Speed Download" packet-mark=\
"Higher Speed Download" parent="Master Queue" priority=1 queue=\
/routing bgp instance
set default as=65530 client-to-client-reflection=yes disabled=no \
ignore-as-path-len=no name=default out-filter="" redistribute-connected=\
no redistribute-ospf=no redistribute-other-bgp=no redistribute-rip=no \
redistribute-static=no router-id=0.0.0.0 routing-table=""
/routing ospf instance
set [ find default=yes ] disabled=no distribute-default=never in-filter=\
ospf-in metric-bgp=auto metric-connected=20 metric-default=1 \
metric-other-ospf=auto metric-rip=20 metric-static=20 name=default \
out-filter=ospf-out redistribute-bgp=no redistribute-connected=no \
redistribute-other-ospf=no redistribute-rip=no redistribute-static=no \
router-id=0.0.0.0
/routing ospf area
set [ find default=yes ] area-id=0.0.0.0 disabled=no instance=default name=\
backbone type=default
/snmp community
set [ find default=yes ] addresses=0.0.0.0/0 authentication-protocol=MD5 \
encryption-protocol=DES name=public read-access=yes security=none \
write-access=no
/system logging action
set 0 memory-lines=100 memory-stop-on-full=no name=memory target=memory
set 1 disk-file-count=2 disk-file-name=log disk-lines-per-file=100 \
disk-stop-on-full=no name=disk target=disk
set 2 name=echo remember=yes target=echo
set 3 bsd-syslog=no name=remote remote-port=514 src-address=0.0.0.0 \
syslog-facility=daemon syslog-severity=auto target=remote
/tool user-manager profile limitation
add address-list="" download-limit=0B group-name="" ip-pool="" name=new1 \
rate-limit-min-rx=408576B rate-limit-min-tx=131072B rate-limit-priority=6 \
rate-limit-rx=408576B rate-limit-tx=131072B transfer-limit=0B \
upload-limit=0B uptime-limit=5m
/user group
set read name=read policy="local,telnet,ssh,reboot,read,test,winbox,password,w\
eb,sniff,sensitive,api,!ftp,!write,!policy" skin=default
set write name=write policy="local,telnet,ssh,reboot,read,write,test,winbox,pa\
ssword,web,sniff,sensitive,api,!ftp,!policy" skin=default
set full name=full policy="local,telnet,ssh,ftp,reboot,read,write,policy,test,\
winbox,password,web,sniff,sensitive,api" skin=default
add bridge="Traffic Control Bridge" disabled=no edge=auto external-fdb=auto \
horizon=none interface=ether2 path-cost=10 point-to-point=auto priority=\
0x80
horizon=none interface="06-Red Barn" path-cost=10 point-to-point=auto \
priority=0x80
horizon=none interface=07-GenTech path-cost=10 point-to-point=auto \
priority=0x80
horizon=none interface=08-Solplex path-cost=10 point-to-point=auto \
priority=0x80
horizon=none interface=09-Omega path-cost=10 point-to-point=auto \
priority=0x80
horizon=none interface=03-Office path-cost=10 point-to-point=auto \
priority=0x80
horizon=none interface=04-LargeDorm path-cost=10 point-to-point=auto \
priority=0x80
horizon=none interface="05-Guest house" path-cost=10 point-to-point=auto \
priority=0x80
horizon=none interface=ether10 path-cost=10 point-to-point=auto priority=\
0x80
horizon=none interface=ether11 path-cost=10 point-to-point=auto priority=\
0x80
horizon=none interface=ether12 path-cost=10 point-to-point=auto priority=\
0x80
horizon=none interface=ether13 path-cost=10 point-to-point=auto priority=\
0x80
/interface bridge settings
set use-ip-firewall=yes use-ip-firewall-for-pppoe=no \
use-ip-firewall-for-vlan=no
set 0 vlan-header=leave-as-is vlan-mode=disabled
set 1 vlan-header=leave-as-is vlan-mode=disabled
set 2 vlan-header=leave-as-is vlan-mode=disabled
set 3 vlan-header=leave-as-is vlan-mode=disabled
set 4 vlan-header=leave-as-is vlan-mode=disabled
set 5 vlan-header=leave-as-is vlan-mode=disabled
set 6 vlan-header=leave-as-is vlan-mode=disabled
set 7 vlan-header=leave-as-is vlan-mode=disabled
set 8 vlan-header=leave-as-is vlan-mode=disabled
set 9 vlan-header=leave-as-is vlan-mode=disabled
set 10 vlan-header=leave-as-is vlan-mode=disabled
set 11 vlan-header=leave-as-is vlan-mode=disabled
/interface l2tp-server server
set authentication=pap,chap,mschap1,mschap2 default-profile=\
default-encryption enabled=no keepalive-timeout=30 max-mru=1460 max-mtu=\
1460 mrru=disabled
/interface ovpn-server server
set auth=sha1,md5 certificate=none cipher=blowfish128,aes128 default-profile=\
default enabled=no keepalive-timeout=60 mac-address=FE:9D:0E:EC:F6:2B \
max-mtu=1500 mode=ip netmask=24 port=1194 require-client-certificate=no
/interface pptp-server server
set authentication=mschap1,mschap2 default-profile=default-encryption \
enabled=no keepalive-timeout=30 max-mru=1460 max-mtu=1460 mrru=disabled
/interface sstp-server server
set authentication=pap,chap,mschap1,mschap2 certificate=none default-profile=\
default enabled=no keepalive-timeout=60 max-mru=1500 max-mtu=1500 mrru=\
disabled port=443 verify-client-certificate=no
/ip accounting
set account-local-traffic=no enabled=no threshold=256
/ip accounting web-access
set accessible-via-web=no address=0.0.0.0/0
add address=10.0.0.1/24 disabled=no interface=ether2 network=10.0.0.0
add address=OMIT disabled=no interface=ether1 network=\
208.83.xx.xx
add address=10.0.0.4/24 disabled=no interface="06-Red Barn" network=10.0.0.0
/ip dhcp-client
add add-default-route=yes default-route-distance=0 disabled=yes interface=\
ether1 use-peer-dns=yes use-peer-ntp=yes
/ip dhcp-server config
set store-leases-disk=5m
/ip dhcp-server lease
add address="Higher Speed" client-id=1:68:94:23:21:40:3e disabled=no \
mac-address=68:94:23:21:40:3E server=server2
add address="Higher Speed" always-broadcast=yes client-id=1:b8:e8:56:2a:b:cc \
disabled=no mac-address=B8:E8:56:2A:0B:CC server=server2
add address="Higher Speed" always-broadcast=yes client-id=1:b0:65:bd:a5:5:a9 \
disabled=no mac-address=B0:65:BD:A5:05:A9 server=server2
add address="Higher Speed" always-broadcast=yes client-id=1:80:e6:50:36:5:8e \
disabled=no mac-address=80:E6:50:36:05:8E server=server2
add address="Higher Speed" always-broadcast=yes client-id=1:60:3:8:ec:f2:66 \
disabled=no mac-address=60:03:08:EC:F2:66 server=server2
add address="Higher Speed" always-broadcast=yes client-id=1:e0:91:53:46:75:96 \
disabled=no mac-address=E0:91:53:46:75:96 server=server2
add address="Higher Speed" always-broadcast=yes client-id=1:4:1e:64:ec:46:bc \
comment="" disabled=no mac-address=04:1E:64:EC:46:BC \
server=server2
add address="Higher Speed" client-id=1:7c:e9:d3:5e:ab:cc disabled=no \
mac-address=7C:E9:D3:5E:AB:CC server=server2
add address="Higher Speed" always-broadcast=yes client-id=1:10:9a:dd:ac:80:c \
comment="Fern- Staff" disabled=no mac-address=10:9A:DD:AC:80:0C server=\
server2
add address="Higher Speed" client-id=1:0:17:3f:b5:db:69 comment=\
"Elizabeth Erkle" disabled=no mac-address=00:17:3F:B5:DB:69 server=\
server2
add address="Higher Speed" client-id=1:e4:ce:8f:2:9c:7c comment=LaDean \
disabled=no mac-address=E4:CE:8F:02:9C:7C server=server2
add address="Higher Speed" always-broadcast=yes client-id=1:34:23:ba:b0:89:7f \
comment=Ananda disabled=no mac-address=34:23:BA:B0:89:7F server=server2
add address="Lower Speed" disabled=no mac-address=00:0B:CD:21:39:93 server=\
server2
add address="Higher Speed" client-id=1:28:b2:bd:76:b6:d7 disabled=no \
mac-address=28:B2:BD:76:B6:D7 server=server2
add address="Higher Speed" always-broadcast=yes client-id=1:9c:4e:36:62:9e:c4 \
disabled=no mac-address=9C:4E:36:62:9E:C4 server=server2
add address=10.0.0.151 client-id=1:24:a4:3c:a2:7e:5d disabled=no mac-address=\
24:A4:3C:A2:7E:5D server=server2
add address="Network Devices" client-id=1:c0:4a:0:f:6d:34 disabled=no \
mac-address=C0:4A:00:0F:6D:34 server=server2
add address="Higher Speed" always-broadcast=yes client-id=1:f8:27:93:80:c7:ea \
disabled=no mac-address=F8:27:93:80:C7:EA server=server2
add address=10.0.0.251 client-id=1:44:d9:e7:22:17:9f disabled=no mac-address=\
44:D9:E7:22:17:9F server=server2
add address="Higher Speed" always-broadcast=yes client-id=1:a4:31:35:a0:bf:73 \
disabled=no mac-address=A4:31:35:A0:BF:73 server=server2
add address="Higher Speed" disabled=no mac-address=20:AA:4B:FB:46:83 server=\
server2
add address="Network Devices" comment=\
"Omega File Server Located in Pump House" disabled=no mac-address=\
00:D0:B8:0A:AF:44 server=server2
add address="Higher Speed" always-broadcast=yes client-id=1:e8:b1:fc:86:b0:14 \
disabled=no mac-address=E8:B1:FC:86:B0:14 server=server2
add address="Higher Speed" client-id=1:28:92:4a:1c:4:7d disabled=no \
mac-address=28:92:4A:1C:04:7D server=server2
add address="Network Devices" client-id=1:0:1f:c6:5f:e:96 comment=\
"UniFi Wireless AP Host Controller Location in Middle Office Back Room" \
disabled=no mac-address=00:1F:C6:5F:0E:96 server=server2
add address="Higher Speed" disabled=no mac-address=00:22:FA:62:FE:1E server=\
server2
add address="Higher Speed" client-id=1:68:5d:43:a7:ca:5b disabled=no \
mac-address=68:5D:43:A7:CA:5B server=server2
add address="Network Devices" client-id=1:24:a4:3c:a2:85:14 disabled=no \
mac-address=24:A4:3C:A2:85:14 server=server2
add address=10.0.0.125 client-id=1:0:20:0:9b:93:be disabled=no mac-address=\
00:20:00:9B:93:BE server=server2
add address=10.0.0.204 client-id=0:0:1b:78:1d:78:53 disabled=no mac-address=\
00:1B:78:1D:78:53 server=server2
add address=10.0.0.0/24 dhcp-option="" dns-server=8.8.8.8,63.251.161.33 \
gateway=10.0.0.1 ntp-server="" wins-server=""
set allow-remote-requests=no cache-max-ttl=1w cache-size=2048KiB \
max-udp-packet-size=4096 servers=63.251.161.33,8.8.8.8
/ip dns static
add address=8.8.8.8 disabled=no name=Google ttl=1d
/ip firewall address-list
add address=10.0.0.50-10.0.0.215 disabled=no list="Lower Speed"
add address=10.0.0.20-10.0.0.49 disabled=no list="Higher Speed"
set enabled=yes generic-timeout=10m icmp-timeout=10s tcp-close-timeout=10s \
tcp-close-wait-timeout=10s tcp-established-timeout=1d \
tcp-fin-wait-timeout=10s tcp-last-ack-timeout=10s \
tcp-syn-received-timeout=5s tcp-syn-sent-timeout=5s tcp-syncookie=no \
tcp-time-wait-timeout=10s udp-stream-timeout=3m udp-timeout=10s
/ip firewall mangle
add action=mark-packet chain=forward comment="Lower Speed Upload" disabled=no \
dst-address-type="" new-packet-mark="Lower Speed Upload" passthrough=yes \
src-address-list="Lower Speed"
add action=mark-packet chain=forward comment="Lower Speed Download" disabled=\
no dst-address-list="Lower Speed" dst-address-type="" hotspot="" \
new-packet-mark="Lower Speed Download" passthrough=yes
add action=mark-packet chain=forward comment="Higher Speed Download" \
disabled=no dst-address-list="Higher Speed" new-packet-mark=\
"Higher Speed Download" passthrough=yes
add action=mark-packet chain=forward comment="Higher Speed Upload" disabled=\
no new-packet-mark="Higher Speed Upload" passthrough=yes \
src-address-list="Higher Speed"
add action=masquerade chain=srcnat disabled=no out-interface=ether1
add action=dst-nat chain=dstnat disabled=yes in-interface=ether1 \
to-addresses=10.0.0.0/24
add action=src-nat chain=srcnat disabled=yes out-interface=ether1 \
src-address=10.0.0.0/24 to-addresses=OMIT
/ip firewall service-port
set ftp disabled=no ports=21
set tftp disabled=no ports=69
set irc disabled=no ports=6667
set h323 disabled=no
set sip disabled=no ports=5060,5061 sip-direct-media=yes
set pptp disabled=no
/ip hotspot service-port
/ip neighbor discovery
set ether12 disabled=no
set ether13 disabled=no
set ether1 disabled=no
set ether2 disabled=no
set 03-Office disabled=no
set 04-LargeDorm disabled=no
set "05-Guest house" disabled=no
set "06-Red Barn" disabled=no
set 07-GenTech disabled=no
set 08-Solplex disabled=no
set 09-Omega disabled=no
set ether10 disabled=no
set ether11 disabled=no
set "Traffic Control Bridge" disabled=no
/ip proxy
set always-from-cache=no cache-administrator=webmaster cache-hit-dscp=4 \
cache-on-disk=no enabled=no max-cache-size=unlimited \
max-client-connections=600 max-fresh-time=3d max-server-connections=600 \
parent-proxy=0.0.0.0 parent-proxy-port=0 port=8080 serialize-connections=\
no src-address=0.0.0.0
add disabled=no distance=1 dst-address=0.0.0.0/0 gateway=208.83.199.241 \
scope=30 target-scope=10
/ip service
/ip smb
set allow-guests=yes comment=MikrotikSMB domain=MSHOME enabled=no interfaces=\
all
/ip smb shares
set [ find default=yes ] comment="default share" directory=/pub disabled=no \
max-sessions=10 name=pub
/ip smb users
set [ find default=yes ] disabled=no name=guest read-only=yes
/ip socks
set connection-idle-timeout=2m enabled=no max-connections=200 port=1080
/ip traffic-flow
set active-flow-timeout=30m cache-entries=4k enabled=no \
inactive-flow-timeout=15s interfaces=all
/ip upnp
set allow-disable-external-interface=yes enabled=no show-dummy-rule=yes
/port firmware
set directory=firmware ignore-directip-modem=no
/ppp aaa
set accounting=yes interim-update=0s use-radius=no
/queue interface
set ether12 queue=only-hardware-queue
set ether13 queue=only-hardware-queue
set ether1 queue=only-hardware-queue
set ether2 queue=only-hardware-queue
set 03-Office queue=only-hardware-queue
set 04-LargeDorm queue=only-hardware-queue
set "05-Guest house" queue=only-hardware-queue
set "06-Red Barn" queue=only-hardware-queue
set 07-GenTech queue=only-hardware-queue
set 08-Solplex queue=only-hardware-queue
set 09-Omega queue=only-hardware-queue
set ether10 queue=only-hardware-queue
set ether11 queue=only-hardware-queue
/radius incoming
set accept=no port=3799
/routing bfd interface
set [ find default=yes ] disabled=no interface=all interval=0.2s min-rx=0.2s \
multiplier=5
/routing mme
set bidirectional-timeout=2 gateway-class=none gateway-keepalive=1m \
gateway-selection=no-gateway origination-interval=5s preferred-gateway=\
0.0.0.0 timeout=1m ttl=50
/routing rip
set distribute-default=never garbage-timer=2m metric-bgp=1 metric-connected=1 \
metric-default=1 metric-ospf=1 metric-static=1 redistribute-bgp=no \
redistribute-connected=no redistribute-ospf=no redistribute-static=no \
routing-table=main timeout-timer=3m update-timer=30s
/snmp
set contact="" enabled=no engine-id="" location="" trap-generators="" \
trap-target="" trap-version=1
/system clock
set time-zone-name=America/Los_Angeles
/system clock manual
set dst-delta=+00:00 dst-end="jan/01/1970 00:00:00" dst-start=\
"jan/01/1970 00:00:00" time-zone=+16:00
/system console
set [ find port=serial0 ] channel=0 disabled=no port=serial0 term=vt102
/system identity
set name=MikroTik
/system logging
set 0 action=memory disabled=no prefix="" topics=info
set 1 action=memory disabled=no prefix="" topics=error
set 2 action=memory disabled=no prefix="" topics=warning
set 3 action=echo disabled=no prefix="" topics=critical
/system note
set note="" show-at-login=yes
/system ntp client
set enabled=yes mode=unicast primary-ntp=216.xxx.xx.xx secondary-ntp=0.0.0.0
/system ntp server
set broadcast=no broadcast-addresses="" enabled=no manycast=yes multicast=no
/system resource irq
set 0 cpu=auto
set 1 cpu=auto
set 2 cpu=auto
set 3 cpu=auto
set 4 cpu=auto
set 5 cpu=auto
set 6 cpu=auto
set 7 cpu=auto
set 8 cpu=auto
set 9 cpu=auto
set 10 cpu=auto
set 11 cpu=auto
set 12 cpu=auto
set 13 cpu=auto
set 14 cpu=auto
/system routerboard settings
set baud-rate=115200 boot-delay=2s boot-device=nand-if-fail-then-ethernet \
boot-protocol=bootp cpu-frequency=1066MHz enable-jumper-reset=yes \
enter-setup-on=any-key force-backup-booter=no memory-data-rate=533DDR \
silent-boot=no
/system upgrade mirror
set check-interval=1d enabled=no primary-server=0.0.0.0 secondary-server=\
0.0.0.0 user=""
/system watchdog
set auto-send-supout=no automatic-supout=yes no-ping-delay=5m watch-address=\
none watchdog-timer=yes
/tool bandwidth-server
set allocate-udp-ports-from=2000 authenticate=yes enabled=yes max-sessions=\
100
/tool e-mail
set address=0.0.0.0 from=<> password="" port=25 starttls=no user=""
/tool graphing
set page-refresh=300 store-every=5min
/tool graphing interface
add allow-address=0.0.0.0/0 disabled=no interface=ether1 store-on-disk=yes
add allow-address=0.0.0.0/0 disabled=no interface=07-GenTech store-on-disk=\
yes
add allow-address=0.0.0.0/0 disabled=no interface=08-Solplex store-on-disk=\
yes
add allow-address=0.0.0.0/0 disabled=no interface=09-Omega store-on-disk=yes
/tool graphing queue
add allow-address=0.0.0.0/0 allow-target=yes disabled=no simple-queue=all \
store-on-disk=yes
/tool mac-server
/tool mac-server mac-winbox
/tool mac-server ping
set enabled=yes
/tool sms
set allowed-number="" channel=0 keep-max-sms=0 receive-enabled=no
/tool sniffer
set file-limit=1000KiB file-name="" filter-ip-address="" filter-ip-protocol=\
"" filter-mac-address="" filter-mac-protocol="" filter-port="" \
filter-stream=yes interface=all memory-limit=100KiB memory-scroll=yes \
only-headers=no streaming-enabled=no streaming-server=0.0.0.0
/tool traffic-generator
set latency-distribution-scale=10 test-id=0
/tool user-manager profile profile-limitation
add from-time=0s limitation=new1 profile=Pauper till-time=23h59m59s weekdays=\
sunday,monday,tuesday,wednesday,thursday,friday,saturday
/tool user-manager router
[XXX@MikroTik] >
