Hello, new user query
Can simple queues + pcq be used for bandwidth control?
Do they work, or if or if I should combine, simple queues + pcq + qos mangle?
Ofcorse they do…
Here you will find a simple example of this https://wiki.mikrotik.com/wiki/Manual:Queues_-_PCQ_Examples
Thanks, from what I could see, I would control the speed in the same way using simple queues + pcq or using mangle + tree.
Correct… ![]()
