Dear Friends,
How to restrict the bandwidth on Particular Interface with 20 Mbps for PC Server / 450G.
Regards
Govind ![]()
Dear Friends,
Regards
Govind ![]()
letβs say you are using ehter1 as your Wan and your server is connected to ether2. then you can simply add a simple queue.
/queue simple
add limit-at=20M/20M max-limit=20M/20M name=queue1 target=ether2
I was about to post a similar thread but I found this one and I am thankful to ahdisml that I have also found the solution of my problem ![]()
you are welcome.
