I have asked this question before, got a few answers, but none that really helped
Maybe I asked the question wrong, so I try again.
I have a MT with an ethernet in, and an OMNI attached to an Atheros card. The wireless interface is in ap-bridge mode and has a live internet IP 192.168.1.1/24. Each client connects and has a static IP. The ethernet IP also has a live IP (192.168.0.1).
Each client has been assigned a static IP, and when connected works fine. My mangle and queues all work when the client (192.168.1.x/24) accesses the internet via the ethernet port, however, here is my problem.
When a client (A) (192.168.1.2) sends data to another client (B) (192.168.1.3), this operates at full speed (uncontrolled), and the wireless performance on all other clients is degraded. Switching off default forward prevents the clients from seeing each other all together, and this is not desired either, they need to connect to each other, at a defined speed.
I switched all my Lucent / Orinoco APās to MT, and the Orinoco APās had a ālimit by mac addressā function, whereby the mac address had a maximum connection speed, even if the traffic was not been routed.
Each client has a live IP (192.168.1.x) with a netmask 255.255.255.0 and a gateway of 192.168.1.1.
All I want to do is limit the speed when 2 clients connected to the same wireless antenna transfer data to and from each other.
Any help will be much appreciated. At this point, setting up a PPPoE server is not an option.
Thanks in Advance
