I’m trying to figure a routerboard (433 or 751) as a bridge that I want to use to limit bandwidth on the Ethernet port(s). I have (by using Winbox) to set one of the Ethernet interfaces to a max bw (Rx/Tx), but still full bandwidth on all ports (All ports are bridged together). Have also tried to create a simple queue with bw limitations, but still full speed.
Is it possible to set bw limitation in bridge mode?
If so - how?
Thanks. Tried to enable firewall (filter in the Bridge menu?) (Using Router OS 6.5). Set up a rule “forward” and had ether1 as In and ether2 as Out interfaces (testing on a 433 board). Still full bandwidth through the bridge. Am a bit confused about the diffeent interfaces in this config - bridge, ether1, ether2 etc.
Any more comments.
Am a bit confused. Had some contact with our Mikrotik distributor. They told me that BW control in a bridge isn’t possible. The answer here seems to indicate that it IS possible…?
Could someone tell me what to do in order to get BW control in a Mikrotik bridge (Ethernet - Ethernet). If not possible in this config - what is the easiest way to set up BW control in Mikrotik (6.5)?
