Bandwidth LIMIT (QoS) per IP for PPP clients
Hi, I have 10 clients on a MT AP which is bridged with my main router ( again MT) wireless subnet is 10.100.10.0/24 . All my clients connect via PPTP and recieve address from the DHCP pool 10.100.13.0/24.
What my problem is - clients get their IP from DHCP and it is never the same ! I could never figure out how to make the bandwidth limit per IP address.
here is a small diagam of my setup:
                                       <----10.100.10.0/24---->    Y       Y
----| DSL box |-----|Main MT|-----------------|WiFi AP|____________|       |___|clients|
                         |__________________PPTP(10.100.13.0/24)__________________|
Static DHCP leases will help you, it binds customer’s MAC-address to IP address. Client obtains the same IP address all the time, if you don’t need complicated QoS configuration than set bandwidth limit with ‘rate-limit’. Option is avaliable for ‘ip dhcps-server lease’.
Use static queues and mangle, if you need advanced QoS.
Sergei thanks for your quick reply i have done this earlier but now
I am going to expand my clients and would apprichiate any solution that is dynamic and there is no need of constatly adding new static queues.
Thanks again in advance! :slight_smile:
Probably, PCQ queues are suitable for you:
  1. first scenario, when all clients receive certain limit,
    http://wiki.mikrotik.com/wiki/PCQ_Examples
  2. second PCQ scenario - bandwidth is equally divided between network clients,
    http://www.mikrotik.com/docs/ros/2.9/root/queue.content#6.54.6.3
What was not clear to me in the 2.9 docs was what we reffer to when we say parent=local ( in my case there were many local Interfaces - every pptp client is acting by it self as a local ) The wiki shows an example where for parent we use global-in and global-out that was the key for solving my problem.
Once again thank you Sergei !
