I have installed 3.0betaRC11 on RB500+CM9 as AP-bridge(wds enabled) and 10 Mktk station-wds clients so pretty straightforward configuration model (Nstreme is not enabled).
If at least 3 clients utilize ~2Mb/s per client (simple download) what makes 6Mb in total on the RB500 Access Point the available bandwidth of that AP doesn’t exceed ~ 100kb/s + extremly high ping time on every client (latency issue).
Point-to-Point (Bridge ↔ station-wds) works well and doesn’t have the same issue.
Does anybody experience the same problems and how to improve AP capability to handle in that scenario 10 wireless clients x 2Mb = ~20Mb in total through wlan1 interface ?
Frankly, I have never seen RB500 + Mktk ROS in AP-bridge mode to be able to handle more than 6Mb/s ! Maybe this is a real limitation of that board or a certain limitation of an Atheros card itself.
Described problem is the same with ROS ver. 2.9.x
Hope somebody will answer this posting.
Thank you,
D.
