Bandwidth limitation per connections
Hello everybody,
I try to limit the bandwidth on some RouterOS devices (like LTE, wAP …).
I have see some scripts or tutorial to limit, but i my case, i search the limitation based on connections when the router don’t manage the DHCP or when the device is behind another router, so not on the IP.
I install many LTE devices, and, in some installation, the bandwidth must be limited, fixed on each users (or connections).
Of course, I’m not trying to limit the bandwidth overall. Any idea ?
Thanks you for you replies.
kind regards
After 2 days of research, i’ve found my solution:
First, before adding any mangle, think to disactivate the fasttrack !
And apply this procedure : https://wiki.mikrotik.com/wiki/Manual:Queues_-_PCQ_Examples
Result : bandwidth applied on all connection with a fixed speed.
