Bandwidth Limited
Greetings
I have the following situation:
Im testing a new PTP from a new Remote Site (10.20.2.x Subnet) Connection from Primary Site (10.20.0.x Subnet) where i have a 500Mb Dedicated Fiber Connection
Remote Site has RB3011 Router (10.20.2.1)
Primary Site has CCR1072-1G-8S+ (10.20.1.1)
If i test PTP Bridged connection directly connected to my laptop i received an IP from 10.20.0.x Subnet and i do a speed Test i have aprox 100Mbps Down and 96Mbps Upload Speeds.
If i connect the PTP Link to the RB3011 Router (10.20.2.1) i connected this to ETH1 that is GIGABIT Port, i created a Bridge (10.20.2.1) and i connect my laptop to ETH2 that is part of the Bridge
and i do a speed test and i get 9Mbps to 10Mbps Avg Download Speed Tests and upload 4 to 5 Mbps Avg…
I enabled Fast Track on Both Routers but havent had any luck …
Both Routers were configured from scratch no default config…
I tested on different ports on the RB3011 Router and i get same results 9Mbps to 10Mbps Avg Download Speed Tests and upload 4 to 5 Mbps Avg
Firmware on both Routers 6.43.8
What other things should i check?
difficult to guess without seeing the config. maybe do a
 export hide-sensitive
and post here?
few things on my mind:
enable Fast forward on your bridge
disable all firewall rule and queue, then test again.
watch Tools - Profile while you test, see what is using your CPU. However I really don’t think the 3011 is lacking the power for what you trying to do.
