Im tring to find a way to limit more than one hotspot user in the same queue, so two or more users will share 512Kbps. I am trying to do this with our radius server but it is not nessesary.
Thank You.
Would you mind to read the manual?
http://www.mikrotik.com/docs/ros/2.8/root/queue.frameset
So what i am tring to do is group user a and b together and then c and z. since with our curent setup we are useing radius with the hotspot and DHCP. So grouping them Staticly by ip wont work. I think we need a way to mangle the users traffic diffrent from hs_auth, and specific to the username. the way the hotspot works we can only seem to limit bandwidth per user with radius or with the hotspot profiles on the MT. Is it possible to assign a profile with radius?
