Hello guys. I have one simple question, how to manage bandwidth on my home network.
I have VDSL line with 16000Mbit download and 2000Mbit upload. On my network are connected mobile phones and notebooks of my childs, and I want setup QoS this way, that my computer, and my mobile phone will have everytime maximum bandwidth available even others are downloading big files or staying on P2P. When I’m not active, others will have maximum bandwidth available. How can I setup this scenarion on my Mikrotik router?
Few methods - easiest if you are unsure how to operate Queues is to simply assign Simple Queues
This can be done a few ways - just limit how much bandwidth each system is given via DHCP - and then static your own and set your priority to be 1 where theirs would be placed at the back end - and given priority of 8
There are a few other methods - but If you are unsure how to play with queues - this is the quick and dirty method.
Are you comfortable with Mikrotik & Queues - or just getting started?
I personally like Queue Trees better - because the system (at least it was like this on version 5 of RouterOS not sure on RouterOS 6.x) goes through every simple queue until something matches - queue trees operate a bit differently where as when in a queue tree all packets will get processed at the same time …
Hello, I’m totally new in Microtic world, so I show you how I try to make it with queues.
I assign static IP to every possible device on my network. Than I make queues where I put on two first places my notebook and my mobile phone. So this devices have unlimited upload and download and priority set to 1. Other devices have upload and download limited to ADSL maximum limits, priority 8 and “Limit at” set to minimum bandwidth if I will be active on my devices. Is it correct? Because I think, that this solution doesn’t work.
If you didn’t specify a limit-at for your priority 1 queues, then this isn’t going to behave the way you want.
Priority is actually more of a tie-breaker with queues. Limit-at is actually a guaranteed minimum bandwidth that is reserved for that queue. If a queue is using less than this, it will receive priority over other queues above their limit-at rates, even if it is priority 8 and the other queues are priority 1.
Basically, all guarantees are met before priorities are considered.
You should either add limit-at guarantees to your high priority queues or else remove all guaranteed minimums and let the priorities fight it out. (of course, in this model, you can hog 100% of the bandwidth and leave none for the kids)
I’d suggest that instead of a queue for each person, create a priority queue and a non-priority queue and set each one up as a PCQ type of queue, and guarantee 50% to the high priority queue, and 50% to the low priority queue.
PCQ will then enforce fair sharing by the devices which are using that queue.
