Hi all,
using WDS and Mesh like the following configuration. Will the total bandwidth be divided for each link in advance or dynamically depending on how much is needed?
For exampe: Bandwidth = 30 Mbit/s, 3 WDS-Links
Szenario 1: Each link gets 10 Mbit/s fix and gets never more
Szenario 2: In case two nodes need no bandwidth, the third node can use 30 Mbit/s
Same Configuration for each node:
interface mesh add name=meshif
/interface mesh port add interface=wlan1
/interface wireless set wlan1 mode=ap-bridge band=2ghz-b/g/n ssid=$ID country=germany frequency=2462 wds-default-bridge=meshif wds-mode=dynamic-mesh wmm-support=enabled
I would appreciate if somebody could tell me which szenario will be the case with the configuration.
Bye Sabrina
