I’m having a problem with a P->MP link. I have a rb333 with 3.23 connected to three CPEs with 2.9.51. Every CPE has hotspot server, dhcp, and ntp client active. All the routing is static (no OSPF, routing package is disabled).
Radio Parameters are well:
Signal strengh -69
tx signal strengh -66
signal to noise 34
ccq 85/89
P throughput 30383
this link is a 5Ghz with Nstreme activated. No disconnections at all. Both sides are CM9 with 15dbm manual tx power.
with these values everything should be well, but actually I cannot do a bandwidth test better that 100k/120k (up/down) and the CPE is quite unusable with this band…
Is there someone that know what is happening? Is it needed a downgrade to 3.20 (or 3.17)?
Any other ideas?
Thank you so much
A.
