Hi
I have setup a hotspot at home with about 10 users. I wish to set bandwidth that each user will use. I noticed that this is possible from the hotspot user profile where there is an option “Rate Limit”. However, what i read so far this option sets the rate limit for the entire hotspot, is that correct?
So assuming that i have only one hotspot user profile, the “default”, and i set the rate limit to 50k/300k. That means all ten users will share the 50/300 bandwidth. Is that correct?
Is it possible to set the rate limit for each user?
