Our site just switched over to 1 Gbs/200 Mbs fiber last week. We have noticed that we can’t get our full speeds through the RB21100AHx2. I tested by connecting a laptop configured with one of our static public IPs directly to the fiber gateway and doing speedtests. On avg, I got 919 down and 190 up, so the ISP is delivering the speeds. The second test was plugging the same laptop into a LAN port on the MT (ports 2-5 are in a switch group with 2 being the master port). The speeds are still high, but went down to 868/187. The real reduction shows when testing from another desktop on the network (connected to the router through a daisychained MT switch. From my desktop, the speeds go down to 546 down/182 up. So, there is definitely something going on in my network that is reducing bandwidth. Is there a tool I can use to see where the bottleneck lies, or what could be possibly blocking traffic? Most bandwidth posts on the internet are about SLOWING bandwidth, but I am looking to MAXIMIZE it. I can post my config if needed to help.
Hi rvr9999,
the first thing I would do, is to look at the cpu usage of the RB21100AHx2 and the cpu usage of the switch. Is any of the devices maxed out?
Second I would try to eliminate the switch as cause; Therefore …
… connect your laptop to the switch and make a speedtest. What is the speed you get?
… directly connect your PC to the router and check your bandwidth. What is the speed you get?
(if possible disconnect all other devices from the switch)
If you really want to go down to the detail there is wireshark. But before that I highly recommend to narrow down the error.
Best regards, Lui
I’m not overloaded. On the RB21100AHx2, my CPU usage fluxes between 1-5%, with 1483/1518 free memory. One switch has 14-20% CPU usage with 105/128 Mb free memory, and the other has 6-15% CPU usage with same memory free. Both switches are connected individually on the RB21100AHx2 in a switch group. So, I don’t think overloading is the issue. I will speedtest with a laptop directly into each switch tomorrow and report the results. Thanks.
Sorry it has taken so long for me to revisit this. I did perform the bandwidth test from each switch, and here are the results:
Test parameters:
used att.com/speedtest for all tests
Brand new laptop w/ core i7 CPU and 8gb ram
Commercial ethernet cable, CAT5e
Three tests on each device, all numbers are Mbps.
Switch 1: 471 down x 186 up, 520 down x 186 up, 426 down x 180 up
Switch 2: 571 down x 185 up, 517 down x 184 up, 358 down x 187 up
RB21100AHx2:798 down x 185 up, 765 down x 188 up, 834 down x 187 up
As I said before, neither switch is overloaded. Any other ideas?
