Bandwidth shaping among several users
I have tried the PCQ setup that is in the documentation:
http://wiki.mikrotik.com/wiki/PCQ_Examples
I have had trouble with this so I have had to setup simple queues for my network.
On one segment I have over 2900 simple queues setup for clients and is getting hard to manage due to the number of ip’s used and queues needed.
What I need is 1 rule instead of 2900 individual rules to set a max limit for every ip to a certain rate.
Example: set every IP in the range of 10.2.1.0/21 to a max limit of 256k down and 1000k up.
I belive PCQ “should” accomplish this if setup right.
Am I right?
Thanks,
Dan-
A lot of useful tips and trick in forum, pls search in forum.
Yes PCQ will do the trick. As it was mentioned in previous post, search the forum, this topic was discussed many times.
Lets say I need to shape ip’s 10.0.0.30 through 10.0.0.254.
When creating a rule I have to use x.x.x.x/24 . This shapes 254 addresses.
Then I need to create exclutions somehow for the first 30 ip’s I do not want shaped.
Is there a way to specify an ip range instead of an subnet?
10.0.0.30-10.0.0.254 instead of 10.0.0.0/24.
Thanks,
dan
Have a look at “address lists”
you can mark traffic etc
Will this work then?
ip firewall mangle add chain=prerouting action=mark-packet new-packet-mark=SHAPE-1 passthrough=no address-list=IP-RANGE-1
/queue type add name=“PCQ_download” kind=pcq pcq-rate=64000 pcq-classifier=dst-address
/queue type add name=“PCQ_upload” kind=pcq pcq-rate=32000 pcq-classifier=src-address
/queue tree add parent=global-in queue=PCQ_download packet-mark=SHAPE-1
/queue tree add parent=global-out queue=PCQ_upload packet-mark=SHAPE-1
Thanks,
Any ideas?
