bandwidth shaping experience/strategy for ~200M traffic
hello, maybe someone has an experience or strategy advice for shaping traffic ~200M and ~250 mil pps
shapping should seperate foreign from local traffic(200 prefixes)
it is desirder to shape 5 different tarif plans for foreign traffic
if trying to do it on a single machine Quadra-core 3.2Ghz Xeon with 2GB with queue tree + mangle for marking local packets,
system can not handle that and several queues are not working
http://forum.mikrotik.com/t/core-router-hardware/16670/1
Perhaps the hardware you are using isn’t up to scratch for coping with this amount of traffic? (Specially if you’re trying to do that many PPS and mangle/queue from the one box)
Also, what queues are you currently using and how are they classifying the traffic?
My first suggestion would be to see how you can refine the way you classify traffic to use the least processing and try and use the PCQ-Queueing to lessen the CPU usage.
Perhaps you might even think about getting in contact with mikrotik to find out the recommended way of doing this.
