Is there any way to monitor current bandwidth usage for an interface?
Like the RX/TX on the interfaces?
Could not find the correct OID for this.
Thanks !
Thanks !
Hi, Yes, you can use Cacti or PRTG Network Monitor to do it.
OID’s are auto-detected.
Regards.
Hey Krafg,
Thanks but i’m using telegraf so i need the OID’s to do this i guess.
Can you see which OID’s that software is pulling or which calculations are done to get those graphs?
I can’t see what OID’s it uses. Only it is based on a generic template and I can gerenate the graphics per interface.
Regards.
