hac anyone compiled BTEST for MAC OSX?
Thanx
Thanx
I’m using it under Crossover for Mac (darWine was a bit annopying with a lot of useless terminal windows opening every time).
It does not work well when testing full duplex but it does the trick most of the time.
also maybe this works, but you need to install darwinports;
http://iperf.darwinports.com/
HERE is the original btest.exe packed as MAC APP with WineSkin , works fine to me…
To use is only unpack the zip file and run… ![]()
BR
Mauricio
Would you happen to have the new version?
is it possible to get the link?
its down
Can you help?
