On 2 of my networks the bandwidth test will not start. I tried both of the test servers on the forum. I’m using tcp and all login info is correct. It’s only happening on 2 of my networks. All the rest are fine. I’m not aware of anything different on these networks. Is there any reason why it’s not working on only these 2 networks? Thanks.
Any ideas? I’m stumped.
Without you posting any detail at all? No.
What detail do you need? I can post just let me know.
I was just wondering if there was anything specific that could cause it not to work.
You have not written anything at all about what your networks look like, how they are connected towards
the bandwith test server, what you tried to debug the problem (e.g. ping the test server), etc etc etc.
How can an outsider know anything about the cause of the problem?
Of course, like always in networking, there could be lots of causes for trouble.
I can tell you we are running 6.37.5 on a CCR109-7G-1C, and the firewall is off.
In theory, shouldn’t the bandwidth test run?
Just thought of sharing, the bandwidth test works if the ip address is configured on a vlan instead of assigning it to a physical interface. So if you want to test on a different network other than the local bridge, create a vlan interface for the new network, assign an ip and associate it with the connecting interface to your intended network. Hope that works for you.
