Bandwidth throttling with diagram
Hi all,
See attached diagram:
I’m trying to do bandwidth throttling but after reading mikrotik docs, I’m even more confused then before.
I basically have a RB1200 at a client site, and they have several smal clients them self all on seperate VLANs. I need to setup bandwidth throttling for each VLAN seperately with seperate dedicated throughput, and there is 1 trunk port that has multiple VLANs on it that I need to setup throttling as a Shared 10Mb link for all vlans on this port.
please see my attached diagram and it will be clearer as to what I’m trying to achieve.
If someone could explain how to achieve this and how to set it up.
Thanks for your help in advance.
anyone?
Ok, I found a document on-line and based myself on that, made a few changes and was able to achieve what I’m looking for.
Here is the document attached
Also available at http://www.smehome.net in the howto’s.
Bandwidth Throttling on Mikrotik Routers.pdf (311 KB)
