Bandwidth Usage History
Is there an easy way for me to track bandwidth usage for each IP on my network? I would like a guide or something for how to set it up. Sorry if this is a noob question but I am getting raped by Comcast as my usage has shot through the roof over the past few months and I want to be able to start tracking it so I can go back and see the total per IP on a monthly basis.
Thanks in advance!
Doug
You can use ip accounting or simple queues.
is it possible to save those data like (logs,graphs,simple queues, accounting) in to plugged USB storage in Mikrotik
so that i won’t run out of disk space or without SNMP server it’s not possible ?
Yes you can create graph using SNMP.
Enable SNMP at ip>snmp
Create graph at tools>graphs
i can see the graphs after adding interface on Tools->Graphing
No need to enable snmp
this what i am looking for —>https://www.lisenet.com/2014/snmp-on-mikrotik-rb751g-2hnd-router/
IT’s good that you have fetched graph as per your requirement.
But it’s mandatory to enable snmp in router to poll the graph from any of the graphing software.
In the mentioned website, it clearly shows how he have enabled snmp and queried from zabbix.
HTH
If you’re looking for sample and easy using graph.
Just go to Queues and make unlimited queue with lowest priority for one user (put user’s IP in target)
then go to graph
and graph your queue.
