Hello I´m not an expert in WANs, and I´d like to know if the bandwicht used by Dude could give me slow responses in the WAN.
I´m monitoring 7 sites, in each site 4-8 devices, I´m monitoring then just with the ping service.
How I know which is the bandwich? how can I set the dude to use the network as less as possible?
Did you put your links between the sites on the map? You can see the utilization on each link…
Right click anywhere on the map select “add link” draw the line between the two sites and pick the correct device/interface and other settings for the link. That will show you all traffic on that interface.
The dude hardly uses any bandwidth. To lessen it even further change the polling time to 1 minute or even 3 or 5 minutes.
