Bandwith Limits
I have latest RouterOS
I have 150Mbit Down / 12-14MBit Up
I want all computers on LAN and WAN to be Unlimited
I want 1 computer to be limited on Upload @ 5Mbit
Basuicly I have a slow upload and want to rate limit the Web Server from wiping out bandwith
I have tried all kinds of simple queue and non limit the bandwith used
can sombody point in right direction
Hi, you should consider using simple queue.
Add target as your webserver internal IP, destination as your WAN interface.
Set MAX limit on download\upload as you need.
/queue simple
add dst=WAN_eth1 max-limit=20M/20M name=limit_lan target=192.168.0.5/32
I found this issue late last night, I had to turn off the fastback in the firewall and then all the normal bandwith rules started to work
Hi
I need to limit my total usage per day. I have a capped solution with RB951 2hnd. I wanna set a total usage limit per day can someone assist in this regard or maybe assist with script. I have to set a daily usage limit of 1GB.
